Page 31 - MetalForming September 2010
P. 31
Reduce Costs & Reduce Lead Times
a fax-back
worksheet
a l l o w s
stampers to
request a
custom tool
built to a
sketch and
required,
specified
tolerances.
Royal
Diversified Products: 401/245-6900; www.royalpins.com
Gas-Spring Wall Chart
Matches Charge Fittings
to Springs
Hyson Products, Brecksville, OH, has issued an updated wall chart that match- es quick disconnects/charge fittings to the appropriate gas spring. The 17- by 22- in. color chart shows each quick dis- connect at its exact size, for simple ID and selection. The photos are matched with a list of the gas-spring models that use each fitting.
Hyson Products: 440/526-5900; www.hysonproducts.com
Tube-Bending Lube
ITW Rocol North America, Glenview, IL, introduces Accu-Lube JL-12, an opaque gel formulated specifically for tube-bending applications. Fabricators can either pump or hand-apply the lube directly to the tube or to the bending man- drel. No cleaning is required before welding, and in applications requiring painting or plating, the gel is easily removed. Compared to using conventional lubricants that flow down tubes, Accu- Lube JL-12 will reduce consumption, improve housekeeping, and prolong tool or mandrel life, according to company rep- resentatives. The gel is available in 5- and 55-gal. containers.
ITW Rocol North America: 847/657-5343; www.rocolnorthamerica.com
For 3D Die Design & Blank Prediction
Logopress3 BLANK Free 14 Day Trial for SolidWorks® or Inventor®
Gold Certified SolidWorks-based software that includes everything you need.
FEA / Flat Blank Prediction software that requires no formal training - for SolidWorks and Inventor
3D Die Design software with ease of use that is often highlighted by our users
Automatically creates 2D drawing files, including title blocks being completely filled out
Spend less time & money, build dies faster with zero mistakes
Sold in over 30 countries around the world Proven industry leader
" that corner from 2D to I know I never would. with Logopress3 so far and I know they went faster than they would have with (2D CAD)." Strattec Security Corporation
testimonials from:
Chirch Global Manufacturing, LLC Berkshire Manufactured Products, Inc. Browning Design
Buhrke Industries, LLC
Oldenburg Metal Tech, Inc. K-Tek Corporation
Rozell Die & Special Tool Gonher de Mexico
and others...
Testimonials
