Page 38 - MetalForming April 2010
P. 38
NewProducts
Automatic Line for Punching and Shearing of Flats
The Geka Alfa 150 automatic line for punching and shearing of flats, developed by Comeq Inc., White Marsh, MD, boasts a small footprint due to its compact self-contained design. The machine will process 4-in. x 1⁄2-in. and 6-in. by 3⁄8-in. copper flats, and includes two CNC- selected punches that can be of two dif-
ferent diameters. Also included is a special nondeforming shearing system. The Geka Alfa 150 employs a simple CNC control for X and Y positioning, to ensure accurate hole punching.
Comeq representatives say that the company is experiencing an influx of ener- gy-related industry requests for the high-
volume fabrication of copper bus bar, and that the Geka Alfa 150 is the perfect machine for the job since bus-bar fab- rication requires multiple holes be punched in multiple places for connec- tion purposes.
Comeq, Inc.: 410/933-8500;
www.comeq.com
Sheet Fanners Handle Heavy-Gauge Steel
Hi-Powr permanent-magnetic sheet fanners introduced by Eriez Manufac- turing Co., Erie, PA, will successfully sep- arate steel sheet as thick as 1⁄8 in. in stacks to 14 in. tall. Semi-sticky, oily and bent sheets can be fanned with ease thanks to a rugged magnetic circuit completely enclosed to withstand severe usage. Units—available in three strengths and four functional heights—feature a durable stainless-steel U-shaped frame with stainless-steel antifriction strips and back cover.
Eriez Manufacturing: 814/835-6000;
www.eriez.com
Super-Strong Robot
Fanuc Robotics America Inc., Rochester Hills, MI, introduces the M- 2000iA/1200 super-heavy-duty robot, able to lift parts weighing as much as 3000 lb. It can support the maximum- rated payload with a 0.6-m offset from the faceplate and with full articulated motion at the wrist. Use it to manipulate truck, tractor and automotive frames, and in similar machine-tending applications. Fanuc Robotics North America: 248/377-7000; www.fanucrobotics.com
36 METALFORMING / APRIL 2010
