Page 85 - MetalForming Magazine October 2022 - FABTECH
P. 85
Custom Hydraulic
Presses &
Press Brakes
for all industries & applications
VISIT US AT BOOTH #B5433
Traveling Clamps for Metal Stamping
Pascal Engineering Booth B5423
Pascal Engi-
neering will present
an array of quick-
die-change (QDC)
solutions for
stamping presses,
all of which can
automate process-
es to help improve
productivity and
reduce downtime. One integral part of a QDC system is clamping, and Pascal’s traveling clamps are driven by an air cylinder which allows their strokes to double.
Starring at FABTECH: the new and improved model TRA traveling clamp, with a traveling speed of 2 sec. for a 600-mm stroke. Its base block is fabricated from aluminum that enables a 30-percent weight reduction over the previous model (20 kg for 600-mm stroke). And it comes with a sprocket for smooth traveling action, and an improved roller chain design to be more lightweight and durable, even when clamps travel overspeed.
www.pascalenginc.com
Abrasive Process Solutions Program
Saint-Gobain Abrasives Booth C13057
Saint-Gobain Abra- sives will debut its Norton Abrasive Process Solutions (APS) program, estab- lished to help cus- tomers determine the optimal grinding or finishing solution for
the application at hand, ranging from simple to complex, off- hand or automated, and for metal fabrication, production grinding and virtually any abrasive operation. The APS program is positioned to be an extension of the customer, where tests can be conducted so that customers do not have to reassign limited inhouse resources and pause their own production.
The APS automation cell can deliver abrasive-to-part and part-to-abrasive applications, wet/dry processing, and use a full range of abrasives such as coated, non-woven, thin wheel, bonded and superabrasives. Equipped with a verified turnkey solution, manufacturers then can contact an automation system integrator to implement the solution. The cell features an industrial robot with a 210-kg load capacity and fitted with an end-of-arm gripper to allow for part-to-media processing, as well as tool changers that use traditional hand tools to perform abra- sive-to-part processing.
www.nortonsga.us/aps
One Dedicated Te
T
ands!
w
woT
eam,
e
rusted Br
r
a
F
om simple, manually contr
aut
we giv
pr
r
olled machines t
omated & integr
o fully ess solutions,
ated hy
dr
o
e the best
esses
W
aulic pr
ey
ou the power t
o manufactur
oducts for your business
Pr
e off
er a full line of the most
compact y
W
et power
ful hy
eather y
aulic
ating a
oy
dr
ou’r
e integr
f
int
eeder, conv
or or r
e
e
obotics, we
e
y
y
o
o
o get
our pr
oduction line t
o
• Can be designed t
accomodate dies of any siz
• Well-suited for part manufacturing that requires superior rigidity & precise bed- to-ram parallelism
• 20 to 2,000 ton capacities
Press Brakes
Whether you have a highly repeatable process that requires a work horse like our K Series, or you are a job shop that frequently changes programs & needs the CNC capabilities of our FK Series to keep up, has a press brake for every application.
• Up to 3,000 tons or more, we’ve got you covered!
PRESSES | PRESS BRAKES | AUTOMATION
e
Manual
| CNC
| Tandem
DESIGNED & BUILT IN USA
82
multipress.com • • 618.262.8666 MetalForming/October 2022
