Page 83 - MetalForming Magazine October 2022 - FABTECH
P. 83
PREVIEWS
small a 2-mm radius.
Also on dis- play: the Flat- Master 55 pre- cision leveler, designed to eliminate resid-
ual stresses in parts, sheets and plates from 0.5 to 15 mm thick.
Corrosion-Inhibiting Coatings, Dry-Film Lubricants
Chemcoaters Booth B4945
Visit Chemcoaters at FABTECH to learn about its patented corrosion-inhibiting InterCoat ChemGuard, dry-film lubricants, acrylics and chemical treatments, sur- face-preparation coatings, and coil cleaning
and reclama- tion offerings. InterCoat ChemGuard is Chem- coaters’ patented family of cor- rosion-inhibit- ing coatings for galvanized substrates— RoHS-compli-
ant and offering key characteristics includ- ing self-healing, adhesion promotion and formability. Not only does it enhance zinc performance, but customers reportedly also can source lower zinc-weight galva- nized substrates such as a HDG G30, and obtain equivalent performance to heavy zinc coatings such as HDG G235.
www.chemcoaters.com
New Presses for Blanking, Progressive-Die and Transfer Applications
Enprotech Industrial Technologies Booth B5957
Enprotech Industrial Technologies, Lansing, MI, a provider of repair, rebuild, modernization and manufacturing-opti- mization services for the metal forming and steel industries, will launch its Enpro- tech E600 Series, a new press program that combines state-of the-art technology with the quality and durability of the Verson and Danly brands.
The presses, for blanking, progressive- die and transfer applications, are designed to increase productivity while reducing the risk of downtime, say company officials, and shorten the lead time for installation and start-up. As part of the program, Enprotech will provide installation, cali- bration and startup services; onsite con- sulting to help maximize productivity; flex- ible control-system options, including a preprogrammed Allen Bradley system or the ability to integrate with any preferred third-party system; and access to in-stock spare parts and perishable replacement components.
en.enprotech.com/press-on
www.arku.com
80
MetalForming/October 2022
LASER BLANKING ACHIEVES UP TO 45 PARTS PER MINUTE
DIE-FREE BLANKING CLASS A QUALITY & STRUCTURAL PARTS
REDUCE CAPITAL EQUIPMENT INVESTMENT:
• Die-free blanking
• No press foundation, loop or press pit, die cranes,
or storage areas
• Acceptable dimensions for lower ceiling heights
• Low noise emissions
OPTIMIZE FOR COST-EFFECTIVE PRODUCTION:
• Accurate & precise check-to-flatten leveler technology
• High-speed & high-volume output results • Continuous flow & speed with 2 lasers
• Smart Track & Trace technology—Schuler’s
Digital Suite solution
SUITABLE MATERIALS:
• High-strength steel • Aluminum
• Stainless steel
7145 Commerce Blvd. | Canton, MI | 48187, USA | +1 734-207-7200
