Page 75 - MetalForming Magazine October 2022 - FABTECH
P. 75
PREVIEWS
Laser Cutting, Press Brake Bending and More
Prima Power
Booth B7917
Prima Power will exhibit its latest tech- nologies for sheet metal processing at FABTECH. Among the machines featured: the Laser Genius+ with Compact Server, developed to cut large and heavy work- pieces precisely and at high speeds. Rated to a trajectory speed of 180 m/min. and acceleration of 2.8 g, the machines come in three sizes and with a range of laser powers to satisfy every application need. Maximum X-Y-axis travel: 6320 by 2200 mm. Integrated software modules simplify processes, and artificial intelli-
gence algorithms provide advanced monitoring and
process control functions.
Sharing the booth with the Laser
Genius+ is the eP Genius 1030 bending cell that combines an eP-1030 servo- electric press brake with automatic tool storage. The result is a productive and flexible bending solution particularly suit- able for small batches.
There’s more—Prima Power also will showcase its Combi Sharp 1530, a compact punching and fiber laser cutting cell equipped with the Compact Express automatic and flexible loading and unloading unit, as well as its software packages to support different levels of production automation. www.primapower.com
Hydraulic Presses— Standard Machines and Custom Designs
Multipress Booth B5433
Multipress personnel will be on hand to discuss the company’s hydraulic press solutions—standard machines as well as
completely customized designs, developed to fit customer specifications and pro- duction requirements. www.pacific-press.com
Straightside Press With Traditional or Servo Drive System
Stamtec Booth B5829
With an extremely rigid, low-deflection box-type straightside frame, Stamtec’s model ST1 press is ideal for stamping pre-
POWER of three
• American Made Ironworkers 45 to 150 Ton Models
• Top Notch Support & Local Service • 3 Year Warranty
Booths BC1530
1 & BC1540
1
m in action & test your material without leaving your place of business, anywhere in the lower 48 States.
Scan QR code or Call (800) 843-8844
www.scotchman.com
FREE DEMO – We bring Scotchman machinery to you. See the
e
PROUD AMERICAN MANUFACTURER EST. 1967
72 MetalForming/October 2022
cision, small parts. When paired with a Stamtec servo feed line, the ST1 can provide high-volume, high-quality parts in an efficient, automated press-production system. www.stamtec.com/st1-series
Turnkey Solutions Targeting
the E-Mobility Market
Nidec Press & Automation Booth B6041
At FABTECH, Nidec Press & Automation will demonstrate its expertise and extensive turnkey solutions for manufacturers in the e-mobility market. Comprised of six respected brands in the metal forming industry, Nidec Press & Automation can offer one-stop solutions for electric-vehicle OEMs and Tier suppliers. www.nidecpa.com
