Page 22 - MetalForming Magazine September 2022
P. 22
press, the more severe the effects of snapthrough. Hence, these clearances periodically should be monitored. While minor progressive wear is normal due to continued press usage, a significant increase in clearances between monitoring peri- ods would indicate accel- erated wear, potentially due to snapthrough.
While no industry stan- dards indicate snap- through limits, good prac- tice calls for monitoring and limiting snapthrough as much as possible.
Reverse Tonnage
Reverse tonnage, or tension in the connecting rods, can lead to struc- tural failures of press- drive components such as wrist pins, slide- adjustment mechanisms and connecting rods. Reverse tonnage also can relate to excessive punch penetration.
In this case, a load
monitor represents a good
starting point to capture
the negative tonnages.
However, as reverse tonnage results from tension in the connecting rods while the load monitor actually meas- ures deflections on the frame, lost information may exist in between. In other words, while a load monitor proves a good tool, measured reverse tonnage values may not always be reli- able. Stampers occasionally should use specialized equipment to ensure that reverse tonnages in the load monitor represent reality.
Due to the ability of the press com- ponents to withstand more compres- sion than tension, forward-tonnage capacity measures much greater than reverse-tonnage capacity. In general, presses are designed to tolerate a reverse tonnage to 10 percent of the
Penetration
Time
Connecting Rods in Compression
Connecting Rods in Tension
Fracture
Typically 200+ ms
Typically 200 ms or less
Snapthrough
Reverse Tonnage
Fig. 2—This load vs. time graph shows snapthrough represented by a sudden drop in load.
Adjustment Screw without Hydraulic Lockup
Adjustment Screw with Hydraulic Lockup
No Hydraulic Preload with Resulting Clearances
Clearance Removed by Hydraulic Preload
MetalForming/September 2022 19
Fig. 3—Reduced clearances can be achieved with mechanisms such as a hydraulic slide lockup, as shown here in a slide-adjustment screw.
press-tonnage capacity. For example, an 800-ton press can handle as much as 80 tons in reverse tonnage. Some press manufacturers offer more robust presses with reverse-tonnage capaci- ties reaching 50 percent of forward tonnage.
Influencing Factors
While many methods exist to esti- mate the forward tonnage in various sheet metal operations, no direct method can estimate reverse tonnage or snapthrough. Nonetheless, consider that reverse tonnage and snapthrough increase with increasing:
• Forming load, influenced by mate- rial thickness and strength, tool geom- etry, and tool timing
• Press inertia
• Press stack-up clearances • Press deflections.
Reducing Snapthrough and Reverse Tonnage
Press design represents a major fac- tor when dealing with reverse tonnage and snapthrough, and as mentioned, reduced clearances in the machine are key here. Reduced clearances can be achieved with mechanisms such as a hydraulic slide lockup, which removes all clearances in the slide adjustment parts (Fig. 3). Other helpful press- design factors include the use of cast- iron components, which dampen vibration, and robust connecting ele- ments such as wristpins.
Reverse Forward Tonnage Tonnage
