Page 20 - MetalForming Magazine September 2022
P. 20
an opportunity to bring in larger parts. We wanted to outfit the press for future work, eying new business opportunities where we might need more stroke length than we need currently.”
“We also worked with Sangiacomo to discuss what part-size ranges we were seeing with our quotes, which also dictated the specs of the feed line,” adds Childers. “We were quoting a little thicker material than Sangiacomo was used to feeding, because we sometimes need to stamp short, thick washers, and other times large thin washers— quite a variety—and we try to accom- modate that whole mix. That’s what led to the decision to use a Universal Feed coil line.”
A Perfect Complement to a Lean Strategy
Wyan and Childers have found the press to fit perfectly into the facility’s drive to become lean, as it’s been busy conducting lean training for its asso- ciates, including instruction on quick die change. Along with staging dies and material for subsequent jobs in
the queue and equipping die carts with all of the tools needed for changeovers, the firm has prepared work instructions for changeovers. Changing out the 200- lb. die that runs on the Sangiacomo, “we can place the die in the press, set it up and have it running in 20 min.,” Wyan says.
“It’s a fun press to run,” he adds, “and we even can adjust the speed of the press while it runs, which proves
helpful when we’re trialing new dies. We can start at 80 strokes/min., for example, then bump it up to 85 or 90 and watch how it runs, then ramp it up to 120 or 140 strokes/min., then adjust it back down if we need to, should part-quality issues arise. How- ever, oftentimes the faster we run the cleaner the cut when we’re blanking. We’re within 0.001-in. repeatability with this press; the precision is there.” MF
UNDER PRESSURE?
Win the fight against wet, dirty air to reduce wear on your pneumatic tools and equipment. Get consistent flows and steady air pressure for optimal productivity and minimal scrap.
Don’t let your compressed air system weigh you down. Trust Kaeser.
Find us at IMTS - Booth #339477
Scan the QR code or visit us.kaeser.com
About Art Metals
Founded 1943, Art Metals Group (acquired by CM Paula in 2012) remains privately owned and operated, focused on manufacturing difficult and custom stampings. Its product mix includes metal washers, stampings and assem- blies, and coined near-net-shape ball and tapered roller thrust bearings.
Its lean-manufacturing plant operates multiple presses with tonnages ranging from 45 to 800 tons, and its toolroom designs and builds progressive and compound dies that can include in-die sensors. It operates from a 70,000-sq.-ft. facility, including a 30,000-sq.-ft. addition completed in January 2022, supplying the global automotive, heavy-truck and other industry sectors.
MetalForming/September 2022 17
us.kaeser.com 866.516.6888
