Page 13 - MetalForming January/February 2022
P. 13
Press capacity range of 150 to 3,375 tons
Ideal for cutting, stamping, bending, embossing, and drawing medium to large parts
Available as standalone presses or fully automated press lines
Automatic lubrication system, slide adjustment, and counterbalance
Press force monitoring for single and sum force
Optimal for both automotive and general stamping industries
time that contributes to more sustainable production.”
“Our next generation of furnaces has a very stable design and are simple to maintain,” says Pär Mickos, AP&T’s product manager, furnace systems. “For example, the heating elements can be replaced much more quickly now, which means shorter downtime that can free up many hours of valuable production time. The furnaces also are more energy efficient— they require lower installed output and have smaller heat losses.”
Other noteworthy features: Should the furnace suffer operational inter- ruptions, the user need only shut off one of the layers while the other layers continue their use; and each chamber is equipped with dew-point control, ensuring every sheet meets customer specifications.
AP&T: www.aptgroup.com
Optimize
Straightener-Feeder
Power Consumption
Based on Sheet
Thickness
Amada Press System America Inc., Erlanger, KY, has introduced its Eco
100% IN-HOUSE PRODUCTION //
Quality Assurance High Precision Long Service Life 850 Stephenson Hwy | Suite 305 | Troy, MI 48083 | +1 248-607-3998 | support@simpac-america.com | www.simpac-america.com
Release mechanism for straightener- feeders, designed to control and opti- mize air-cylinder pressure while pro- cessing sheet. By optimizing pressure based on sheet thickness, the mecha- nism promises to reduce power con- sumption by as much as 50 percent and reduce CO2 emissions, say company officials.
SERVO SOLUTIONS //
Eco Release-equipped products, designed to contribute to metal formers’ sustainability efforts, include several mod- els of straightener-feeders for coils to 51 in. wide and with sheet-thickness capacity to 0.354 in., and can be retrofitted or installed new with various press systems. Amada Press System America Inc.: www.amadapresssystem.com
MetalForming/January-February 2022 11
