Page 9 - Metallforming Magazine December 2020
P. 9
Wintriss Introduces
New Die-Protection
Sensors
Wintriss Controls Group, Acton, MA, has introduced a new line of sensors for protecting stamping and forming dies, including broader-range proximity sensors, short- and long-range diffuse reflective sensors, a distance-settable optical-tri- angulation sensor, and an ultra-long-range infrared through-beam sensor.
The new proximity sensors reportedly have four times the range of similarly sized inductive proximity sensors. Also introduced: proximity sensors that ignore ferrous metals and instead only detect nonferrous alloys. These sensors prove very useful when detecting parts made of aluminum, brass, phosphor-bronze or copper, while a typical proximity sensor will detect the tooling more readily than the part in those cases.
The new long-range diffuse reflective sensors use infrared rather than visible light, to minimize false actuations caused by oil mist in the sensing field. Use the special distance-settable optical-triangu- lation sensor in challenging applications where a part must be detected against objects such as a chute. And, Wintriss developed the ultra-long-range Infrared through-beam sensor for use in lubrica- tion-intensive environments.
All of the new sensors are IP-67-rated to withstand harsh in-die environments and are available to purchase online. Wintriss: www.wintriss.com/store
Perfecting Die Design Software for Over 30 Years
