Hot off the Press
Coe Press Equipment Supplies Two Coil-Feed Lines to Wico
Wednesday, July 25, 2018
Coe Press Equipment, Sterling Heights, MI, has delivered two new coil-processing lines with integrated coil end welders to Wico Metal Products, Warren, MI, a provider of large stampings to automotive OEMs and Tier 1 suppliers. Both of the lines are equipped to process high strength steels (HSS) up to 60,000-psi yield.
The first line includes a COE 54-in. servo roll feed, 54-in. by 20-ft. dual threading table, 50,000-lb. by 54-in. coil reel, and 4-in. by 54-in. straightener with 6-in. pinch rolls. The second line includes COE’s 72-in. servo roll feed, 72-in. by 16-ft. dual-threading table, 60,000-lb. by 72-in. coil reel, and 4-in. by 72-in. straightener with 6-in. pinch rolls.
Both lines feature power straighteners equipped with automatic lubrication systems, non-marking chrome rolls and a heavy-duty alligator peeler-dekinker station for hands-free threading and top or bottom payoff ability. The 54-in. line system has a roll speed to 362 ft./min. and straightener payoff rate to 80 ft./min. The second line system has a roll speed to 296 ft./min. and straightener payoff rate to 80 ft./min. Feed accuracy on both lines is + 0.003 in. In addition to the traditional coil line equipment, the lines feature MES Zipwelders for shearing and welding coil ends together.
For more, click here.
YOUR NAME *
EMAIL *
WEBSITE
