Facilities
Penn Stainless Products is Laser-Beam Cutting Thick Stainless-Steel Plate
There are 1 comments | Post a comment
Saturday, December 1, 2012
A new Tanaka TF6000 6-kW laser-cutting machine installed at Penn Stainless Products, Quakertown, PA, is outfitted with optional nitrogen-gas-flow technology that enables cutting of stainless-steel plate to 11⁄8 in. thick. Cutting envelope: 13 by 62 ft., with a tolerance of ±0.10 in. and less than 1 deg. of edge taper.
See also: Tanaka Kousakusho Corporation
Posted by: Vijesh Mehta on 2/11/2017 1:25:55 AM - URL: http://www.siddhagirimetal.com/hr-cr-sheet-plate-c
YES,laser technology is most widely used for the cutting of the stainless steel. Regards,Siddhagiri metals and tubes. For more info visit us at: http://www.siddhagirimetal.com mail at: export@siddhagirimetals.com
