Tooling Update
Transfer Roller Bars Without Lift
Wednesday, April 1, 2009
Hilma Division of Carr Lane Roemheld Mfg., Ellisville, MO,
Transfer roll bars without lift
introduces a new transfer roller bar that promises high load-bearing capacity without hydraulic lifting. Use the bars on die tables outside of the press with lifting roller bars in the press bolster to provide simple and convenient die transfer. Segments can mount front to back to any desired length, or can be used in rows of two to double load-bearing capacity. The units come in three sizes.
Hilma Div. of Carr Lane Roemheld: 800/827-2526;
See also: Hilma Div. of Carr Lane Roemheld
