Servo Presses to 330 Tons
March 1, 2008
Seyi Presses, Walnut, CA, has announced the North American debut of its new servo-press technology, initially available in single- and double-point connections with capacities from 121 to 330 tons. The presses feature high-torque, low-rpm servo motors designed to provide greater energy at low speeds, allowing stampers to efficiently produce highly accurate parts from difficult-to-form materials.
Seyi’s control comes standard with conventional crank, blanking, drawing, coining and multiple-hit profiles, and memory for additional customer-programmed profiles. A touchscreen displays slide-motion curves, machine status and fault codes.
www.seyiamerica.com
Industry-Related Terms: Blanking, Coining, Drawing
See also: SEYI America, Inc.
