High-Speed High-Performance Press
Saturday, March 1, 2008
High-speed high-performance press
The new BSTA 200-60 BE press from Bruderer Machinery, Ridgefield, NJ, combines precision mechanics and modern electronics. The heart of the machine is a short, rigid main shaft mounted in the transverse direction. The power of the ram is transmitted via two connecting rods, the lever system and two pushing rods. Hardened and ground spindles for ram adjustment are mounted outside of the power flow, allowing precision setting of ram height during punching.
See also: Bruderer Machinery, Inc.
