Tooling Update
Roller-Cam Catalog
Wednesday, October 1, 2008
Anchor Lamina, Farmington Hills, MI, presents a 12-page color catalog describing its LamCam RollerCam, designed to function at one-million hits plus. A specifications chart provides work stroke, maximum force, return force and mounting-screw size for 11 RollerCam models, for use with Dadco or Kaller gas springs. Work stroke ranges from 50 to 95 mm; maximum force from 3.3 to 16.9 tons; and return force from 133 to 668 lb.
Included in the catalog are exploded-view drawings and complete component-parts’ lists, and a schematic drawing of the RollerCam in a typical piercing application.
Anchor Lamina: 248/489-9122;
See also:
