Materials & Coatings
Nonhazardous Corrosion Inhibitor
Thursday, May 1, 2008
Workplace cleanliness and environmental safety make Armor Protective Packaging’s newest product a natural complement to its current line of corrosion-inhibiting products.
The company, based in Howell, MI, has introduced Metal Rescue, which can safely and effectively remove iron oxide from metal-alloy products in as little as 20 min., leaving the base part and other materials (including the user) unaffected. The nontoxic liquid solution does not contain harmful hazardous acids found in alternative rust-removal systems. The product is noncorrosive, nonflammable, nontoxic, biodegradable and contains no VOCs, solvents, acids, bases or hazardous ingredients.
Water-based, the product is safe for aluminum, brass, copper, chrome, gold, lead, nickel, silver, titanium, tungsten, solder or solder points. Plastic, glass or cloth can be cleaned as well without damage to other materials.
Armor Protective Packaging: 517/546-1117;
See also: Armor Protective Packaging
