Rugged Hopper Ideal for Workstations
December 1, 2019Comments
At FABTECH 2019, Steel King Industries, Inc. introduced the ScrapHopper, an addition to the company’s industrial steel-container line, which boasts rugged, corrugated-steel sides, and features two-way entry tubes, fully rotatable heavy-duty casters, and a push handle that makes it simple to maneuver. Fork tubes enable simple dumping. Units feature a 4000-lb. capacity, and are available in two standard sizes, 32 by 40 by 24 in., and 40 by 48 by 24 in. The standard ScrapHopper model is meant for use with solids, but can be fitted with an optional drain plug and manufactured with a fully welded interior for use with liquid products.
See also: Steel King Industries, Inc.
There are no comments posted. Pressroom Automation
Tuesday, May 7, 2024
Industrial Magnetics Names Frank Connor Regional Manager
Friday, April 19, 2024
Option Allows Clamp to Sense Presence of Sheet Metal Panels
Thursday, April 4, 2024
Lift and Tilt Table Lowers to Floor Level for Hand Pallet-Tr...
Friday, March 8, 2024
Customized AMRs
