Levelers, Coil-Processing Equipment
March 1, 2008
Levelers,Coil-processing equipment
Herr-Voss Stamco, Callery, PA, showcases its precision levelers by processing sheets of material with serious shape defects through the leveler and turning the sheets into prime material. Whether your material is 1 or 0.008 in. thick, the firm has a leveler to fit the application. In addition to levelers, Herr-Voss Stamco builds cut-to-length, tension-leveling, loop-slitting and its patented Strand Extensioner slitting lines.
www.gen-world.com
See also: Herr-Voss Stamco
