Autonomous Bin Picking Kit for Process Tending
April 13, 2020
From Universal Robots (UR), ActiNav promises to simplify the integration of autonomous bin picking of parts and their accurate placement in machines and processes using the company’s collaborative robots (cobots). ActiNav synchronously handles vision processing, collision-free motion planning and autonomous real-time robot control, eliminating the complexity and risk usually associated with bin-picking applications.
UR-Machine-Tending-TeachAutomated bin picking, traditionally a challenging process, requires significant integration and programming efforts, with most bin-picking products focused solely on the vision aspect of bin picking, according to UR officials, and often require hundreds of lines of additional programming to bridge the gap from pick to place, especially when placing goes beyond dropping into a box and involves accurate insertion of a part into a fixture for further processing. Conversely, ActiNav autonomous bin picking reportedly allows manufacturers to achieve high machine uptime and accurate part placement rapidly, with few operator interventions.
ActiNav combines real-time autonomous motion control, collaborative robotics, and vision and sensor systems in a single kit, requiring no vision or robotic programming expertise It is based on a teach-by-demonstration principle using a six-step, wizard-guided setup process integrated into the UR cobot teach pendant, and can be deployed by manufacturers’ inhouse automation teams or through assistance from a UR distributor or integrator. Autonomous motion control enables ActiNav to operate inside deep bins that hold more parts; something that standalone bin-picking vision systems struggle to accomplish, according to UR officials.
“Machine tending has always been one of the mainstay applications for our collaborative-robot arms,” says Jim Lawton, UR vice president of product and applications management. “We discovered a significant market need for a simple solution that enables UR cobots to autonomously locate and pick parts out of deep bins and place them precisely into a machine. This is not pick and drop; this is accurate pick and part-oriented placement. This minimizes floor space and reduces the need for part-specific tooling.”
ActiNav is available through UR’s distribution channel and via the new UR+ Application Kits platform, an ecosystem of components certified to work seamlessly with UR cobots. ActiNav works with UR’s UR5e and UR10e e-Series cobots, a UR+ component or user-defined end effector, and application-specific frame or fixture as needed. The kit includes the Autonomous Motion Module (AMM) and ActiNav URCap user-interface software, along with a choice of 3D sensors.
Industry-Related Terms: Fixture, Lines
See also: Universal Robots
Technologies: Additive Manufacturing
