Page 26 - MetalForming July 2019
        P. 26
          Toledo Integrated Systems Toledo Transducers, Inc.
One Source, One Solution
• Tonnage Monitors • Press Controls
• Load Cells
Fabrication
and performance characteristics. Applying the right power, abrasive and tool for each is what makes a given grain choice most effective.
As mentioned earlier, ceramic and zirconia wheels perform best on high- er-amperage tools, but not as effec- tively on a lower-amperage tool, where an aluminum-oxide wheel requiring less torque performs better. When in doubt, use the highest-amperage tool available.
Using a higher load speed and a higher RPM means that the wheel has a higher surface speed and makes more contact/min. with the material, leading to a noticeably faster cut as compared to a lower-amperage tool. With the lat- ter, operators often press harder to improve cutting speed, causing more friction and heat, and potentially dam- aging the abrasive.
Signs of Running
at the Wrong Speed
A tool not running at the right speed starts to bog down when the operator applies pressure. This could be due to inconsistent power to the tool, or to a failing motor. For pneumatic tools, it could be because the seals are opening up, signaling time to rebuild the tool.
If an operator runs a disc too quickly or applies too much pressure with a flap disc, the glue holding the flaps to the disc may give off an odor. The oper- ator should ease up on the pressure or double check the tool-to-consumable- RPM ratio to ensure that the tool and disc are rated for each other.
Check the Rating of the Tool and Abrasive
When choosing the right tool and abrasive for the job, the operator should check the product packaging and operator manual to ensure that the product rating equals or surpasses the tool’s RPM. This helps maximize efficiency and productivity while ensur- ing a safer workplace.
When in doubt about product or tool selection, consult a trusted dis- tributor or abrasive manufacturer for help. MF
  Toledo Integrated Systems Toledo Transducers, Inc. www.ToledoIntegratedSystems.com 800-T-Toledo • 419-867-4170
  24 MetalForming/July 2019
