Page 21 - MetalForming July 2019
        P. 21
                  Spinning stage Spun Part
tf
Mandrel
Fig. 2—Forming action in shear spinning.
spinning, the roller not only forms the blank against the mandrel, but it also applies a compressive force while it moves, stretching the material over the mandrel in a single pass while the outer diameter of the finished part remains
equal to the original blank diam- eter (Fig. 2).
The stress conditions required to cause metal flow requires the shearing angle to be less than 80 deg. Depending on material properties, the minimum angle required for shear spinning will be between 12 and 18 deg. Shear spinning cannot produce cylin- drical shapes, due to the vertical walls having a 0-deg. shear angle.
The shear spinning process applies compressive stresses onto the blank to cause yielding, put- ting it in the same group of metal forming processes as bulk form- ing, extruding and ironing.
Flow Forming
In flow forming or tube spinning, the wall thickness is purposely reduced, with the required increase in workpiece length dictating the extent of the reduction.
Flow forming appears similar to metal spinning, but the process
requires dedicated flow forming equip- ment. It involves the deformation of a rotationally symmetrical hollow part clamped between a rotating mandrel and tailstock. Deformation occurs by localized radial pressure from (usually) three rollers applied simultaneously. Metal flow conforms to the contour of the mandrel inside.
Tubular blanks commonly (but not exclusively) are used in flow forming processes, with the tubes ideally pro- duced from material with low flow stress, high tensile-strength-to-yield- strength ratio, high-tensile elongation and high reduction in area.
An Economical Technique
Spinning processes can produce a variety of products economically. Examples: vases, baskets, basins, bowls, kettles, blower housings, fans, filters, nozzles, ladles, cones, cups, funnels, venturis, domes and drums.
Next month: key process and tooling parameters for metal spinning. MF
Tooling by Design
 Blank
      to
     Diameter
           Roller
           When it tak
f,
es off
, al quality
      Admir
r
Over 65 years of quality and dependability go into all of our
 ides along.
       carbon and alloy steels. Y
our parts and components demand
o
    the same commitment. Whether it’s air
craft quality 4130, or any of our AMS-certified low and high carbon alloy steels,
    trust Admiral’s tradition of first-class quality, on-time delivery, and personalized service. Contact us for a quote today!
        TM
TM
              teel.com ISO 9001 REGISTERED
est 123rd Str
Ph: 800-323-7055 Fax: 708-388-9317
email: sales@admiralsteel.com
Admir
a
l
lst
t
          4152 W
e
eet Alsip, Illinois 60803-1869
             Admiral is a r
egister
ed trademark of Admiral Steel LLC. Alsip, Illinois. Reg. No. 2430959. All rights r
eserved.
                                RESIS
S
T
T
T
T
A
A
A
AN
NCE
G SUPPLIE
                E
                       W LDIN
G
S
S
     RIGHT P
ARTS A
RIGHT NOW!
A
T THE RIGHT PRICE,
T
MetalForming/July 2019 19
WWW.TJSNOW.COM | 800-NOW-SNOW
