Page 40 - MetalForming-January-2019-issue
P. 40
MANUFACTURERS OF: Industrial Fluids, Metal Working Lubricants & High Heat Corrosion Resistant Coatings
• Metal Working Lubricants
• Gear Lapping Compounds
• Corrosion & Heat Resistant Coatings
• Metal Forming Lubricants & Drawing Compounds
• TechDraw FT 400 Drawing Compound approved by: Ford, GM, FCA, Nissan, Honda and Brose
Controlled pattern spray lubrication technology. Spray only where your process requires.
II Programmable spray in 2" x 2" squares across your blank II Control spray area with up to 8 lube quantities
II Auto blank learning capability with recipe storage II Mist extraction ensures a clean environment
II Reduce lube consumption and post-processing II Increase overall operational efficiency
PROUDLY SOLD AND SERVICED THROUGH THE AMERICAS BY:
7600 Kensington Court, Brighton, Michigan 48116 | FortechProducts.com Toll Free (800) 252-6516 Office (248) 446-9500 | sales@fortechproducts.com Fax (248) 446-1500
9601 York Alpha Dr., North Royalton, OH 44133 USA 800.800.5368 I sales@kenttesgo.com
KENTTESGO.COM
38
MetalForming/January 2019
