Page 74 - MetalForming October 2014
P. 74
Previews
Fluid Forming Provides Dimensional Accuracy
strokes/min. and with 2-m bolsters or smaller, the transfer system can maintain a high level of precision and accuracy.
FluidForming Americas Booth B1134
Sander Automation also provides stan- dard through-the-window and HST trans- fer systems in two- and three-dimension- al configurations using advanced motion control. www.sanderautomation.de
FluidForming will display its deformation process that precisely shapes sheetmetal into a pre-
defined geometry by using fluid under high pressure. The deformation process utilizes
water at pressures up to 60,000 PSI as the direct force- to-form, while maintaining absolute control of die sur- faces and thus eliminating die deflection.
By applying a uniform force
to the sheet, the fluid shapes
it into the form of the tool.
The process results in uniform distribution of sheet thicknesses and avoids abrupt changes in stress, ensuring high dimensional accuracy and stability. www.ffamericas.com
High-Speed Servo-Transfer Systems
Sander Automation Corporation Booth B1151
Sander Automation Corp. will shine the spotlight on its latest product, the ZGV 200/ ZHGV 200 high-speed servo-transfer system. Ideal for high-speed presses rated to 150
72 MetalForming/October 2014
