Page 22 - MetalForming March 2023 - PMA Chairman Jeff Aznavorian
P. 22
after all of that, many companies will need to call the integrator back in each time that a traditional robot needs reprogramming.
4. Specialist Application Kits
Cobots are powerful platforms for performing all manner of applications, from screwdriving and sanding to inspection, machine tending and pal- letizing. As a result, an entire industry has arisen that builds on cobot plat-
forms to provide specialized peripherals and software designed to tackle specific applications. These kits contain everything required to get start- ed quickly on an application.
Look for a cobot supplier that can provide an ecosystem of certified third-party solutions spe- cially designed to take on press brake, stamping and other pressroom appli- cations. These application kits remove a lot of the guesswork involved in cobot deployment, and ensure rapid deploy- ments, lower TCO and faster ROI than both ad hoc and traditional automation
solutions.
5. Champion
“Without a project champion or
ambassador,” says Mayse, “your like- lihood of succeeding is almost nonex- istent.”
Identify someone within the organ- ization that can take ownership of the project and champion the solution. Without a cobot ambassador, the proj- ect likely will lack a focal point and your company won’t be well-placed to make the most of collaborative automation’s speedy deployment times. Well-made cobot systems can be used by employees with no previous robotics experience, so don’t assume that the cobot champion must have a huge amount of robotics or technical expe- rience. The champion could be a gen- eral associate with a good eye for process efficiency and an enthusiasm for new technologies. MF
I
I
S
SO
O
9
90
1:
:2
20
15
5C
MetalForming/March2023 19
Ce
e
r
rt
tified
V
Vi
i
Cobots in the PressRoom
Progressive Metal Stamping Dies: From Simple to Complex
For over 40 years, JK Tool has been a strategic partner to the Automotive, Medical & Aerospace industries; designing & manufacturing high-speed carbide progressive stamping dies, as well as high-volume production machining components.
We are tooling experts & understand the dynamics & requirements of your stamping needs.
Let us help with your project jterzolino@jktool.com
JK Tool
148 Prominence Drive New Kensington, PA 15068 724.339.1858
isit us at jktooinc.com
Mid Atlantic Machinery’s cobot-based stamping- and press brake-tending solu- tion comes with a cobot arm, specially designed grippers, a proprietary machine- control interface and accessories such as part-feeding carts. The system can per- form hardware insertions, and tend stamping press and press brakes, as shown, right out of the box. Photo courtesy of Mid Atlantic Machinery.
