Page 14 - MetalForming Magazine February 2023 - Metal Forming for the Automotive Industry
P. 14
KEEP SPARKS FLYING WITH KAESER.
Perfect for the metal forming industry, our rotary screw compressors ensure increased productivity by reducing maintenance, downtime, and energy consumption.
SCAN TO LEARN MORE us.kaeser.com/metalforming 866-516-6888
Tooling by Design
tially eliminate secondary processes such as heat treating, coating and nitrid- ing. Where such processes already are applied, peening improves the results.
Laser heat treating describes a process in which a laser beam focuses onto the tool-steel surface being treat- ed. With proper control, the laser ener- gy raises the surface temperature above its martensitic-transformation tem- perature. When the beam switches off, the thermal mass of the die section promotes rapid self-quenching, result- ing in formation of the desired marten- site microstructure and giving the material its required hardness and wear properties. This process increasingly has become popular due to precision control and application of heat to local- ized areas, resulting in minimal dis- tortion and residual stress input.
Testing various metal forming lubri- cants for comparison can be time-con- suming and risky to production tools, with many lubricant formulations based upon wet-bench chemistry, not actual field trials in an actual tool. Lubricant suppliers and manufacturing companies can take advantage of stan- dardized cup-draw-test tooling to eval- uate results for a variety of trial lubri- cants and sheet metal substrates. This may prove an especially important step in lubricant selection when processing different grades of AHSS materials. Test results show correlation to real-life press applications, thus limiting the risk to actual tools.
Real-time nondestructive produc- tion-monitoring tools have been used widely for various manufacturing processes such as joining and fabrica- tion. And now being realized: applica- tions of real-time and nondestructive evaluation tools to monitor and assess incoming coil properties, blank surface finish/lubrication, die stresses, part tem- perature, final stamping quality such as springback and geometry tolerances.
Eventually, your company or die shop must deal with disruptions cre- ated by new technology. Your response will be determined by how you perceive these disruptions. MF
“CAN I GET 500 COPIES OF THAT ARTICLE?”
Have you been wanting extra copies of an article published in MetalForming for your own promotional efforts—trade shows, meetings, mailings, AND MORE?
REPRINTS ARE COST EFFECTIVE AND WILL
PRODUCE A HIGH-QUALITY PIECE OF LITERATURE
FOR YOUR PARTICULAR NEEDS.
We do all the work, and you’ll have your reprints in three weeks—all at a SURPRISINGLY LOW COST!
CONTACT Sue Cubranich at 216-901-8800/scubranich@pma.org for more details.
MetalForming/February 2023 11
