Page 32 - MetalForming magazine • December 2022
P. 32
“While a normal hinged steel conveyor may work for an application, a conveyor specifically designed for the application can eliminate future problems and increase longevity,” Reak says. “Con- sider the size and weight of parts, chips or other scrap; vol- ume; and dryness. Also con- sider material type. Alu- minum, for example, may require different conveyor design features than high-car- bon steel.”
Conveyor manufacturers offer solutions for the tough- est applications, such as Jor- gensen’s X-Treme Duty con- veyors. Such systems feature robust construction with belts and drives catered to the spe- cific materials to be moved. Hinged-belt, mesh and mag- netic belts are options avail- able from manufacturers to meet specific application needs, with various conveyors available with additional clearances between the belt and casing that allow for material to pass through without jamming.
Unique conveyor options, such as this rubber-belt conveyor for gen- tle movement of class-A-finish parts, give metal formers and fabrica- tors many choices when looking to provide the most effective solu- tion for an application.
incline for the application. Part size determines cleat spacing, as the cleats hold material and enable orderly incline and decline movement. “Cleat spacing for a 16- in.-long stamped part will differ quite a bit than for a 3-in.-long part,” Reak says. “The cleats must function correctly when the part reaches an incline. And, the cleats move closer to each other during the lower curve transition, so that must be accounted for to prevent
jams.”
Also, pay heed to incline
angles and discharge heights. “Too-steep inclines may prevent the part from falling when it reaches the top, causing it to get stuck,” says Reak. “And, consider the dis- charge height, where parts or scrap fall off of the con-
veyor and into a bin.”
An excessive discharge
height may cause damage to parts or lead them to bounce out of bins. Conversely, a dis- charge height set too low may lead to parts or scrap being pulled back into the
The key here: Consult
with your conveyor supplier when specifying equipment, and be ready with answers.
“We ask all kinds of questions related to the materials, volumes and more to arrive at the optimum solution,” says Reak. “This helps us determine belt options, ruggedness and more. Some of the higher-carbon steels cause a lot of wear and tear on conveyor components, so we need to know that. We also want to know if a user will require oil recla- mation of liquid filtration, as that affects what systems and options to employ.”
Also, consider future applications.
“We want to know if a user might be using harder materials in the future,” Reak says. “It may be less expensive long term to install a heavy- duty conveyor now that can run the normal application with little wear
and then transition seamlessly to tougher work. This is especially impor- tant for job shops that don’t know what might be running in the future or that must switch between a variety of applications.”
In some cases, belts can be switched out on the same conveyor case to han- dle tougher applications as needed. Other options for tougher applications include a hinged steel conveyor belt with a "pork chop" side-wing design from Jorgensen that delivers a flush, jam-resistant wall, Reak notes.
3. Achieve the Proper Layout
Ideal conveyor performance, even with the best system supplied for the application, requires an effective layout and setup. This includes proper cleat spacing, belt pitch, apron-plate style and
conveyor as its underside contacts parts or scrap from filled bins.
4. Synch With Line Equipment
Options exist for tying conveyors into stamping or other production lines. For example, “we can incorporate a variable-frequency drive to automat- ically engage the conveyor when the line runs,” Reak says, “which helps in implementing lights-out operation. Also assisting with unattended opera- tion: automated conveyor-health mon- itoring to reduce jamming and damage, and automatic clearing of scrap, dust and other items that can lead to jam- ming or excessive wear. And, we can integrate a sensing device that moni- tors conveyor rotation, which prevents piles of parts or scrap due to an inactive conveyor.” MF
MetalForming/December 2022 29
Fabrication: Material Handling
