Page 6 - MetalForming November 2022
P. 6
For
tek-Maine F
xible Fab
ication Syst
ms
m
m
Fle
r
r
e
e
designed to your production r
equir
emen
t
t
s
Formtek-Maine
Flexible Fabrication System
can produce your blanks from
ms
- orming. Our purpose-built, flexible fabrication
m coil stock. Systems can be equ
ipped with a va
riety of features including cutoff, punching, notching, slitting, bendi
solutions enable you to create a wide variety of different parts on the s
ng, and roll
f
f
are backed by an industr
y-leading warranty and
24/7 technical suppo
ame system
rt. For mor
e
information call or visit our website.
m. All Formtek-Maine equipment and systems
e
i
i
t
t
t
t
i
in
l
sheets without stopping the
a new pallet is inserted and suspended over the full stack to continue stacking while full pallet is removed from stacker bay. Lift table then raises to take new pallet and insertion mechanism is retracted.
hing station with interchangeable
sizes, and configurations of punches and shapes of notches.
Punc
tooling adds different quantities,
h
In-line part inspection
Slitter arbor with adjustable
hing and notch
Pallet insertion system
k
i
ng in multi- cations or for
k
n
ives blanking applic
f
for s
l
l
f line.
oval
of
f
f
ul
l
t
allows remo
f
tab
b
l
l
e
l
l
st
t
ack
k
of
-up rollers automatically shuffles
conveyor into the inspection area. Hard stops for X and Y location provided on one side and string encoder with digital readout mounted to the other side to measure strip length.
with pop-
slitter blade access door and digital or computerized slitter blade indicator can be added to reduce setup time during part changeover.
T
manually adjustable or powered into location.
o
ooling stations can be
Tel. 800-247-COIL (2645)
Email: sales@formtekmaine.com
www.formtekmaine.com
