Page 32 - MetalForming November 2022
P. 32
panies where aluminum often gets the call,” he explains. “Overall, we shipped 4.5 million parts last year for some 120 different active customers. We also sup- ply the bar industry, aftermarket auto- motive, HVAC and even prisons, among others.”
Among its most recent capital- equipment investments, to maintain pace with its growing customer base: a new robotic-welding cell, added in 2019 to take over for its aging work- horse. “We still use that old robotic welding workcell occasionally,” Reiker says, “but only out of necessity as demand requires it.”
The new welding cell on the block: an OTC Daihen Eco-Arc 200, with OTC Daihen’s exclusive Synchro-feed weld- ing package designed to provide ultra- low spatter, and ideal for the wide mix of material thicknesses at Haake, espe- cially thin-gauge parts with outside corner welds. Anchoring the cell is a model FD-B6 six-axis arc welding robot—6-kg payload capacity, 1445- mm reach and built-in wrist motors to avoid interference with jigs and work- pieces. It also boasts built-in cables to avoid weld-conduit interference and improve torch reach. And, OTC Daihen touts a seamless, high-speed digital connection to the welding power sup- ply and a built-in mechanical shock sensor as part of the package.
Aluminum Welding Shines
“Researching our robotic-welding options in 2019, we really appreciated the ability of the OTC Daihen cell to shine when welding aluminum,” Rieker says, also noting that the cell’s flexible tilt-turntable positioner allows it to complete complex weldments without requiring the robot to perform acro- batic maneuvers.
“We have one job, for example, welding an aluminum tube to a bracket for an assembly used in the sign indus- try, which requires a convoluted cir- cular weld path,” he explains. “We can use the tilt-turntable to maneuver and spin the part under the stationary weld- ing torch to maintain the proper torch orientation to the weld joint.”
The OTC Eco-Arc
production robotic
arc welding systems
are two-station, two-
table configurations
that allow an operator
to unload a finished
weldment and reload
parts into a fixture on
one worktable, all
while the robot welds
on the second table.
OTC offers the sys-
tems in several configurations—as a cobot production cell, a compact cell, a cell with fencing that anchors to the floor, a cell with the fencing mounted to a common base and large cells featuring long-reach robots and larger weld tables.
Haake’s system employs the OTC Daihen Synchro-feed gas-metal-arc- welding setup—500-A inverter-based pulsed power supply (OTC Daihen model WB-P500L) and weld-wire delivery system—that, OTC Daihen officials say, virtually eliminate weld spatter. Via a welding process called PulseDip, the setup incorporates a servo-driven wire feeder within the torch body that advances the welding wire forward to create the arc, and then precisely retracts the wire while syn- chronizing with a weld-current wave- form that extinguishes the arc. The result: consistent droplet transfer into the weld joint with minimal if any spatter.
The WB-500L power supply employs OTC Daihen’s Wave Pulse process that delivers high-speed waveform control, for spatter control as well as to mini- mize undercut during high-speed weld- ing. OTC Daihen also touts the power supply for eliminating the need for expensive helium-based shielding-gas mixtures, enabling instead the use of 100-percent argon on aluminum, and argon-CO2 mixtures when welding stainless steel.
Simpler to Program and Run
“Compared to our older robotic welding cell, we’ve found the Eco-Arc much simpler to program and operate,” Rieker says, noting that his program-
Haake’s robotic welding cell features OTC Daihen’s exclusive Synchro-feed welding package designed to provide ultra-low spatter, and proves ideal for the wide mix of material thicknesses at Haake, espe- cially thin-gauge parts with outside cor- ner welds. Anchoring the cell is a model FD-B6 six-axis arc welding robot with built-in wrist motors to avoid interference with jigs and workpieces.
mer can develop new robotic welding routines in 1 to 2 hr. using a teach pen- dant at the cell.
“And, while previously the operator tending our older cell required a lot of expertise in welding to avoid quality issues,” he adds, “when that operator left the company, we were able to replace him with a cell operator who knew how to program robots but lacked that higher level of welding expertise. That’s because the OTC Daihen welding system is so intuitive and forgiving; the operator does not need to have a lot of welding skill or knowledge. This new cell really does make it much easier for
MetalForming/November 2022 29
