Page 70 - MetalForming Magazine October 2022 - FABTECH
P. 70
on every machine cycle. Operating similarly, a new pulsed counter cam output is pro- grammed with an “on angle” and a dwell time instead of an on-off output.
Also highlighted: ShopFloorConnect software that collects downtime and pro- duction-efficiency data from CNC machines and presses in all areas of discrete man- ufacturing. Data are displayed in real time, and manufacturing reports are produced, including detailed OEE reports in a variety of formats. Wintriss will showcase the new ShopFloorConnect PM Tracker that allows users to track important machine preven- tive-maintenance (PM) items by run-hours or machine cycles, issues targeted alerts when an item requires PM, and tracks the maintenance work history for all machines. ShopFloorConnect 6.0 also fea- tures a new Universal Interactive Application Program Interface that enables users to quickly set up two-way data sharing with any ERP or MES software. www.wintriss.com
Sustainable Lubrication
Industrial Innovations Booth B6245
Excess gas emissions are a direct result of improper lubricant-dilution ratios, excessively applied volume or inaccurate lubricant placement. Reclaiming oils instead of disposing makes environmental and economic sense. Industrial Innovations will showcase its sustainable lubrication- management programs at FABTECH, designed to address all ESG scopes. Its Pro-Mix proportional mixers, Spra-Rite application and Reclaim-Pro recycling sys- tems promise to substantially reduce overall consumption, prevent overuse and lower users’ carbon footprints. www.industrialinnovations.com
Consistent, Even Lubrication
Unist
Booth B5728, B9627
Unist will display its precision roller systems designed to apply fluid consistently and evenly across both sides of the stock. Advanced fluid tracking lets metal formers stretch fluid further, and the SmartFlow control connects directly to the press, giving metal formers access to these features directly from the press control panel. www.unist.com
TAKE IT
Running out of space? Compressor room too hot?
Find us at FABTECH Booth #B5409 Take a tour inside
us.kaeser.com/solutions 866.516.6888
PREVIEWS PREVIEWS
