Page 39 - MetalForming Magazine October 2022 - FABTECH
P. 39
Integrating Automation with a Servomechanical Press
Bob Southwell
Vice President, Domestic Sales Aida-America Corp.
PARTNER CONTENT
How is press automation typically integrated with a conventional flywheel mechanical press?
With the introduction of servo-based coil-feed and transfer systems, this equipment typically has been inte- grated into conventional flywheel presses via a press- mounted resolver or programmable limit switch outputs from the press control. Setpoints (in deg.) are calculated for the beginning and end of the automation cycle, dependent on clearance within the tooling. The maximum allowable press speed relates to the time available (in mil- liseconds) between the setpoints vs. the required time for the automation to complete its cycle.
What challenges do metal formers face when integrating a servomechanical press with
automation?
With a conventional mechanical press, including link- motion presses, the automation time (in milliseconds) is fixed to the press stroke rate. With a servo press, as stroke rate and ram speed can vary, so can the available automa- tion time. With the ability of servo presses to run in pendu- lum motion and perform rapid restrikes, it’s not possible to run the automation off of a standard rotary press resolver, as is historically done. A linear encoder can be used to account for servo-motion profiles, but is limited in interface and requires recalibration with each change in motion.
So, how then can stampers integrate automation to a servo press control?
There are two main methods. The first: Have the servo-press control house all of the automation-con- trol functions. This means that the metal stamper must work within the automation options provided by the press manufacturer.
Another option: Look for a servo-press interface with a virtual encoder option. Equipped with this feature, the
press control prepares a virtual encoder signal based off of the programmed servo-motion profile. This creates “virtu- al angles” for the automation equipment to follow, as if it is following a mechanical press resolver signal, and, there- fore, permits utilization of the standard transfer program, irrespective of the actual slide motion. This allows integra- tion of the end user’s preferred automation equipment and potential incorporation of compatible third-party transfer screens into the press control.
What other challenges do stampers face when integrating a coil-feed system?
The main challenge, which also represents an opportu- nity to improve productivity, occurs when running progres- sive dies in a servo press in pendulum mode. As the stam- per begins to optimize the stroke rate and reduces stroke length to increase run rates, the feed window also begins to decrease. It is important to understand the feed-length capabilities with shorter feed windows (75, 90 or 120 deg.). We often recommend that stampers upgrade their straight- ener throughput speed by around 50 percent so that the feed line does not become the limiting factor. If consider- ing a combination feeder-straightener, stampers should look closely at these rates, as they require opening and closing all of the rolls for the pilot release. Adding a servo pilot release on the feeder can help with these challenges.
How about challenges related to integrating part-transfer equipment?
The optimization of the automation portion of the servo press stroke is more complicated with a trans- fer system than with a coil-feed system. There can be sev- eral different limiting factors affecting press-line output. We recommend that stampers look at simulation software that accounts for the tooling and that they work closely with the press manufacturer’s servo application engineers to provide optimization training to those working on the pressroom floor.
36 MetalForming/October 2022
