Page 28 - MetalForming Magazine September 2022
P. 28
decontamination systems and more. With the support of sister plants in Knoxville, TN (25,000 sq. ft.), and Rich- mond, WA (36,000 sq. ft.), it sends treat- ment systems all over the continent, and the world, including supporting the safe shutdown and restoration of the Fukushima reactor in Japan.
Most often the AvanTech pre-fabri- cation (cutting and forming) depart- ment and fabrication team (welding) work with structural and carbon-steel sheet and plate, 1⁄4 to 2 in. thick, “although we have cut carbon steel to 6.5 in. thick on the waterjet,” Coleman says. “And, we also fabricate plenty of stainless steel, including duplex grades. We use the waterjet on just about every job that runs through this shop.”
As many as 20 projects can dot the shop floor in some form or fashion at any one time, some taking as long as 4 to 5 months to complete, “and often waterjet cutting is the first step,” Cole- man shares, “so bringing that process inhouse has been critical to minimizing our lead times and optimizing our abil- ity to react to customer needs.”
AvanTech installed its waterjet machine (an Omax 120X Series JetMa- chining Center) in mid-2021, and it’s been a workhorse ever since, often run- ning two shifts/day. “In fact, when our Omax rep recently visited he noted that the machine had logged 5 yr. worth of cutting time in just 1 yr.,” Coleman notes.
A Huge Work Envelope
The abrasive waterjet machine, with a cutting envelope of 33 ft. 4 in. by 10 ft., boasts a 50-hp EnduroMax pump, and A-Jet software-controlled multiaxis cutting head that provides three modes of automatic taper compensation. This feature, say Omax officials, minimizes taper on finished parts and provides a cutting range from 0 to 60 deg., enabling cutting of beveled edges, angled sides, countersinks and complex 3D shapes.
“We fabricate a lot of pressure ves- sels, as well as lifting lugs, gussets and other little pieces that we assemble to the vessels,” says Coleman. “Tube and pipe sections, too, and prior to the
The Omax JetMachining Center at Avan- Tech features a cutting envelope of 33 ft. 4 in. by 10 ft., a 50-hp pump, and soft- ware-controlled multiaxis cutting head that provides three modes of automatic taper compensation. The workhorse machine allows the firm to fabricate pressure-vessel plate sections and heads, as well as lifting lugs, gussets and other pieces that it assembles to the vessels.
waterjet machine we often would hand- cut and manually drill holes rather than send the work outside. Now with the waterjet we can efficiently, and with much greater quality, provide our weld- ing department with precision-prepped weld edges, making the welding process more efficient and also with optimum quality. I’ve cut domed vessel heads on the waterjet where the welders didn’t have to perform any edge grinding on the weld joints prior to welding.”
Dimensional accuracy from the machine, driven from the Omax Intel- liMax software (CAD, CAM, and process and machine parameters) is a given, Coleman says. “And often, within a day of entering a job into our production system, we can be cutting parts on the Omax,” he adds, “compared to a week or more when we outsourced the work.”
Shop-Floor Programmability
While the firm has a dedicated pro- grammer using the IntelliMax software in the engineering office, two operators have been trained to program the cut- ting machine on the shop floor. They simply input into the machine control the material type and thickness, work- piece-to-mixing-tube offset and the required cut-quality level, and the con- trol software calculates cutting speed.
While AvanTech bought the machine primarily to cut pressure-vessel and container plate and domed heads, it also equipped the machine with a rotary axis, useful for cutting and drilling holes in tube and pipe.
“Just this week we cut three 1-in.- thick domed heads and used the machine to cut out holes to accept three nozzles in each of the heads rather than task our welders with cutting those holes,” Coleman says. “Just the cut time on that alone saved our welders three days in terms of laying out a head, using a flame-cutting torch to cut the holes, and grinding to prep weld edges. With the waterjet we had the job completed in less than one shift.
“In another recent case, we had a big project fabricating large steel plates assembled into an 8-in.-thick shielding vault,” he continues, “used to store con- tainers of radioactive waste. The vault required tight tolerances and intelligent stacking of the plate sections to prevent radiation leaks. That job would have been far more difficult without waterjet. Each plate was 2 to 4 in. thick and was stacked in a stair-stepped pattern. We waterjet-cut all of the plates and they fit together like a glove, with nice tight weld joints. If we had outsourced that job to a shop, whether using waterjet or plasma cutting, costs and lead times would have significantly increased.
“We see the waterjet as a great com- petitive advantage,” he adds.
Originally, Coleman had estimated a 2.5-yr. payback on the machine invest- ment, but being that it’s running as much as 60 to 70 hr./week, “I’m sure that is considerably shorter now,” he says. MF
Fabrication: Waterjet Cutting
MetalForming/September 2022 25
