Page 26 - MetalForming Magazine August 2022
P. 26
SUSTAINABILITY STARTS HERE
3 ESG-FriendlyTM 1 RECLAIMATION
70%
Reclaiming oils instead of disposing just makes environmental and economic sense. RECLAIM-PRO coolant purification systems are known for reducing lubrication requirements by as much as 70% while also decreasing machine downtime and waste haul costs.
2 DELIVERY AND APPLICATION
PROPORTIONAL MIXING
The emission of excess gases
(ESG Scope 1) can be a direct result of using the incorrect lubricant, an improper dilution ratio, excessively applied volume or inaccurate lubricant placement, which ends up burning off into the atmosphere.
1:1 to 1:150
Precise regulation of your dilution ratio results in better overall process control.
MIX
RECLAIM
SPRA-RITETM application systems regulate volume of lubricant applied at specific areas of your metal working process. Proper location will substantially reduce your overall consumption, prevent overuse and lower your carbon footprint.
WE CAN HELP YOU ADDRESS ALL THREE ESG SCOPES
Industrial Innovations has almost
40 years of experience in providing strategic lubrication management programs for industrial environments. Using a comprehensive approach,
we assess your operations to ensure that you get the right combination of equipment and services for your needs.
industrialinnovations.com
(616) 259-0399
APPLY
