Page 23 - MetalForming Magazine June/July 2022 80th Anniversary Issue
P. 23
Tooling by Design
Spring-Loaded Pilot
Upper Form Punch (Spring-Loaded)
Lower Form Punch
Fig. 2—A bottom-action form station in the closed position.
0.010/0.020-in. Overtravel Gap
Spring Pin
Adjustment Washer
Plunger Pin
Rocker
punch contacts the strip before the lower form raises. A rocker that pivots on a pin as well as a plunger pin acti- vate the lower form punch. This pin has an adjustable washer under the
requirements. Forming at high speeds becomes more difficult with the need to always keep the stock strip straight throughout the tool—no lifting of the strip off of the die surface. This requires
the use of form punches that raise from the bottom of the die and then return in order to allow feeding of the strip.
Fig. 2 shows a bottom-action form station. The upper spring-loaded form
ATLANTIC TOOL & DIE CO.
ENGINEERS AND MANUFACTURERS
Congratulations
on your 80th Anniversary!
HQ: Strongsville, OH • Sharon Center, OH • Seville, OH • Harlingen, TX Matamoros, Mexico • San Jose, Costa Rica
www.Atlantictool.com • 440.238.6931
20 MetalForming/June/July 2022 www.metalformingmagazine.com
Atlantic Tool & Diev2.indd 1 5/11/22 9:06 AM
