Page 9 - MetalForming February 2022 Special Automotive Issue
P. 9
THE NEW PRO SERIES
DEVELOPED SPECIFICALLY FOR TIER SUPPLIERS
Automatic Feed Company, long known for its automotive OEM high speed coil processing lines, has taken its industry experience to create the high quality, dependable compact PRO SERIES coil lines. These press feed lines are perfect for processing non-surface critical inner body panels or stamped parts from a variety of materials — be it UHSS, AHSS or aluminum. This equipment can feed coil directly into a blanking or stamping press, shear or laser cell.
Each PRO SERIES line is comprised of a single reel and coil cart, peeler, straightener, threading table, press feed, and controls package that enables integration between the press and the coil feed line.
Visit automaticfeed.com to find out more and download our brochure.
Capabilities
Width: PRO 40 up to 40" PRO 60 up to 60" PRO 80 up to 80"
Thickness: 0.020" – 0.25" Speed: Up to 164 FPM
Material Strength: Aluminum, up to 350 MPa; Steel, up to 1200 MPa
Coil Weight: Up to 60,000 lbs and up to 80" OD Yield: Aluminum up to 50 ksi (350 MPa) and
Steel up to 174 ksi (1200 MPa)
Footprint: PRO 80, the largest, is approximately
WORLD-CLASS COIL AUTOMATION SOLUTIONS
476 East Riverview Avenue Napoleon, Ohio 43545 United States of America
Contact us:
+1 419.592.0050
40' x 30'
automaticfeed.com
