Page 22 - MetalForming February 2022 Special Automotive Issue
P. 22
survey of noteworthy forming
and welding developments. Conducted for AISI by Metal- Forming magazine columnists Danny Schaeffler and Eren Bil-
lur, the survey reveals more
than 25 enabling technologies of note; here we discuss just a handful of those related to metal forming.
Steel tube air forming (STAF)— Here, a press-hardening steel (PHS) tube is preformed in a small press at room temperature, and then trans- ferred to the main press where it is heated to the critical temperature using electrical conduction by passing cur- rent through the tube. After heating, the first forming step creates the flanges where the press closes on the partially air-blow-formed tube. In the second step, air pressure completes the process by forming the desired cross-section and overall shape.
Parts made with the STAF process can have a flange area for further weld- ing/joining to other car-body compo- nents. Some peripheral parts can be integrated into a single STAF part, improving productivity and manufac- turing cost. The continuous closed cross-section is created without the need for spot welding, improving stiff- ness and reducing manufacturing costs.
Hot metal gas forming (HMGF) with conductive component heating— Used in the Ford Focus and Bronco and the Jeep Wrangler, HMGF com- bines the advantages of hydroforming (increased rigidity and functional inte- gration or elimination of joining oper- ations) with those of press hardening (very high strength).
Roll forming with 3D bending— This approach, also called 3D roll and sweep by Shape Corp., which devel- oped the process for fabricating 3D- shaped tubes for roof-rail and A-pillar applications, can replace hydroforming to create smaller profiles. The result is improved driver visibility, added inte- rior space and better airbag packaging. When used in the Mustang Mach E and 6th-generation Ford Explorer and Escape, the process improved strength-
20 MetalForming/February 2022
Patented by Posco in 2017, the roll stamping process, which can be implemented on a convention- al roll forming line, enhances the ability to create shapes and features not in the rolling axis.
to-weight ratio by more than 50 percent and led to an overall mass reduction of 2.8 to 4.5 kg per vehicle.
Flexible roll forming—This process employs CNC-directed forming rolls that can move axially and also rotate to follow part contours. Thus, it allows the forming of parts whose cross-sec- tions change over their lengths.
Roll stamping—Patented by Posco in 2017, this process, which can be implemented in a conventional roll forming line, enhances the ability to create shapes and features not in the rolling axis. Using an automotive door impact beam as an example, Schaeffler and Billur describe using the process to simultaneously form the W-shaped profile in the central section and the flat section that attaches to the door inner panel. This process eliminates the need for brackets or internal spot welds.
“A global automaker used this method to replace a three-piece door impact beam made with a 2.0-mm PHS-CR1500T-MB press-hardened steel pipe,” they write, “that required two end brackets to attach it to the door frame, with a one-piece roll- stamped CR900Y1180T-CP complex- phase steel impact beam. This substi- tution resulted in a 10-percent weight savings and 20-percent cost savings.”
Acoustic-emission (AE) signal mon- itoring to detect tool wear and lubri- cation variability—AE can be used to monitor punch-force signals, with dif- ferences related to changing friction conditions. Analysis of variation in punch-force signatures reveals infor- mation about the friction state of the process, helping to understand tool- wear progression and variability in the lubrication process.
Closed-loop intelligent process control—Schaeffler and Billur draw attention to the growing need for metal formers to adopt Industry 4.0 solutions, citing intelligent process control as an
example. The idea is to acquire and process, in real time, key variables from forming operations, including material data, lubrication conditions, process settings and draw-in measurements. Part of the data, then, is used for feed- forward control for immediate quality control along the production line.
“Applied in production of sinks with austenitic stainless steels, which also has the TRIP effect,” write Schaeffler and Billur, “the concept should be applicable to 3rd Gen and other AHSS. (There is a) high likelihood that this or a similar concept makes it into auto production.”
Online draw-in measurement and active blankholder-force (BHF) con- trol—Used by Volkswagen during deep drawing in specific applications, active BHF control helps to control material draw-in. Increasing BHF helps to avoid wrinkling, but excessive BHF may lead to cracks. While typically the deep- drawing process applies a constant blankholder force throughout the stroke using either a hydraulic cushion or nitrogen cylinders, VW AG uses lasers to measure draw-in during the forming process and then locally adjusts BHF using piezo-actuators. It applies the technique for forming the steel spare-wheel well of several VW models, as well as the aluminum hood outer of the Audi A3.
Similarly, explain Schaeffler and Bil- lur, researchers at the Institute for Metal Forming Technology in Stuttgart, Ger- many, developed a die that features a segmented elastic blankholder with 10 hydraulic pistons, one for each seg- ment. Each piston applies a different blankholder force to the corresponding segment, comparable to a die cushion with fully independently controllable pistons. A piezo-electric sensor deter- mines the stress in the part wall to allow the process to adapt for process variables such as tribological effects,
