Page 19 - Metallforming Magazine December 2020
P. 19
The new Linear Transfer servo-transfer setup offers a vastly larger—and pro- grammable—motion profile when com- pared to the mechanical transfer system it replaced. Capacity of the new system: 1500-mm pitch, 750-mm clamp and 300- mm lift. The 5800-mm-long tooling bars carry 18 Norgren receivers, with a maxi- mum payload of 175 kg.
ton transfer presses.
Speaking to the recent and planned
press-automation upgrades, Moore notes that, “even as we continue to invest in new capital equipment at our facilities, these upgrades to existing presses have allowed us to be very aggressive in quoting new work, and to bring in takeover tools when our customers ask us to. The flexibility and adaptability of the servo-based transfer equipment also enable quick and effi- cient changeovers, while allowing us to run most tools at, or very close, to the maximum run rate of our presses.”
Larger and Programmable Motion Profile
While the old mechanical transfer system on the 1500-ton press at the Barrie plant had a fixed motion profile of 1100-mm pitch, 300-mm clamp and 150-mm lift, the new servo-transfer setup offers a vastly larger—and pro- grammable—motion profile: 0 to 1500- mm pitch, clamp motion to 750 mm and a maximum lift of 300 mm. The 5800-mm-long tooling bars carry 18 Norgren receivers, with a max payload of 175 kg.
“The expanded motion profile, and its flexibility, has been a game changer,” Moore says.
In addition, while the old and obso- lete transfer system limited production run rates to 12 strokes/min. for most jobs, the new system typically runs at the rated press speed of 20 strokes/min.
Included with the servo-transfer system retrofit project is this end-of-line 8000-mm- long dual conveyor, accompanied by exit-side guarding.
MetalForming/December 2020 17
The press processes blanks produced inhouse, and runs 1.5 shifts/day, “soon to be 2.2 shifts/day,” Moore says. “And, we expect to be running at three shifts/day sometime in 2022.”
Much of the work running on the newly upgraded transfer press com- prises six new tools awarded from a Tier One customer, “a testament to the flexibility of the transfer system,” Moore says. “Most notable is the increased pitch capacity, which allowed us to take on these new tools. There’s no way they could have run on the old system with just 1100 mm of pitch.
“We’ve maximized the entire win- dow of the press,” Moore continues, “as well as the lift axis. And, we worked with Linear Transfer to customize all of the start-stop angles. All of this newly found process flexibility has allowed us to run a wider variety of part and tooling sizes.”
Moore also notes how the flexibility of the servo-transfer system allows the press to run what he refers to as “unique” tools.
“For example,” Moore offers, “to run one of the newer tools, we can pause the transfer system where we don’t have quite enough clearance and where we need to get a tooling finger around a guide post. As the press ram moves past 180 deg., we can hold the pitch axis to delay it from returning, pause the transfer until the press begins to open, and then restart the pitch motion.”
Other Transfer Retrofits
Regarding the other two transfer-
system retrofit projects at MatcorMat- su, at its facilities in Brampton and in Ohio, Moore says that the completed Brampton retrofit occurred on a 1996- vintage blank-fed press. That setup employed an older servo-transfer sys- tem that was installed below passline and used a carousel-type infeed destacker.
“It ran at a very low stroke rate,” he says, “and the below-passline setup caused a lot of draw oil and other con- taminants to infiltrate the ballscrew and lift-pinion gears, which became a routine maintenance headache. We had to tear apart the entire mechanical system at least once per year. Overall equipment effectiveness was poor, the press was in dire need of help, and the new transfer system, installed early in 2020, came to the rescue.”
That press also has been upgraded with a new high-speed pick-and-place unit, running a combination of transfer dies.
The Ohio transfer-system upgrade is due for installation early in 2021.
“You can’t improve if you don’t invest,” says Drummond. “If you tour all of our facilities throughout North America, you’ll find a lot of new equip- ment, including a new 2000-ton press and 3000-ton press installed recently in Mexico. As our customers look for us to take on more and more work— often larger and more complex dies, and projects involving higher-strength steels and aluminum work—we remain committed company-wide to adding equipment, growing capacity and expanding our capabilities.” MF
