Friction Cups Grip Slippery Materials
Friday, August 23, 2019
New from Piab, DuraFlex friction cups, a line of suction cups designed to provide grip on oily and wet surfaces. A special grip pattern enables operators to safely and reliably move slippery metal goods without slowing production lines, and allows manufacturers to reduce product droppage and lower scrap rates.
The cups feature a rough cleat surface and sharp cleat edges and channels. This design creates greater friction and a stronger hold compared to traditional-traction suction cups, according to company officials, noting that normal cup abrasion resulting from handling oily sheets does not degrade the shear-force performance of Piab’s friction cups over time, translating to longer cup life.
The cups reportedly maintain their hold on heavy and slippery sheets during accelerations and de-accelerations, especially in cases of emergency stoppage. All parts are maintained in the proper position to facilitate applications such as stamping, reducing scrapped products and improving overall line sustainability. Made of DuraFlex polyurethane, the cups will not break or crack after exposure to ultraviolet light, heat or ozone, which is an issue with cups comprised of rubber compounds, claim Piab officials.
To prevent surface damage on thin metal sheets common in automotive and large-appliance applications, the cups feature a dual-hardness design and soft cup body. Sealing the cups to part surfaces requires lower vacuum force than with other types of cups, meaning gentler handling. Also, the soft cup lips mold easily to curved surfaces, resulting in less vacuum leakage and stronger grip.
The cups also maintain their elastic memory and original shape for an expanded life cycle. Fewer cup replacements result in costs savings and reduction in waste, helping manufacturers meet their sustainability goals. Additionally, the durability and effectiveness of these friction cups, according to Piab officials, enable manufacturers to use fewer cups if production speeds allow.
Several DuraFlex models are available. Use the BFF model for handling concave and convex surfaces, or the FCF model for increased stability when handling larger metal sheets. For products with narrow surfaces, Piab also offers friction cups in two oval shapes.
See also: Piab Inc
YOUR NAME *
EMAIL *
WEBSITE
