Hot off the Press
Coe Ships Press Feed Line to Metal Fabricator
Monday, October 28, 2019
Coe Press Equipment, Sterling Heights, MI, has shipped a coil processing line to a Minnesota contract stamper and fabricator of metal components and assemblies, specializing in deep-draw stamping and serving a variety of industries. The new coil-feed line can handle coil widths up to 30 in. and coil weight up to 10,000 lb. Designed for processing mild cold rolled steels with 45,000 psi yield, from 0.035 to 0.250-in. thick and to 0.125-in. thick with materials at 40,000 psi yield, depending on material width. The roll speed rate can reach 318 ft./min.
The line consists of a ServoMaster Series 4 Roll Feed with SyncMaster line controls, along with Work Roll Advisor Settings on the screen. SyncMaster controls allow the operator to manage many of the servo feed, straightener, and coil reel setups and functions from a single touchscreen, including line speed averaging loop control, loop-depth setting by recipe and automatic lubrication control.
The 30-in. power straightener features 3.5-in. dia. work rolls and 5-in. dia. pinch rolls for optimum straightening capability. Standard features also include a pneumatic raise and lower of upper pinch rolls, and optimized roll diameter and center distance. The 10,000-lb. capacity coil reel can accommodate 72-in. diameter coils and is equipped with a hydraulic traveling coil car and remote job pendant. The line also has a 30-in. by 20-ft. threading table with an adjustable passline feature.
YOUR NAME *
EMAIL *
WEBSITE
