Four Cures for Sheetmetal-Shearing Defects
During the early stages of a sheetmetal-fabrication process, shears often get the call for cutting straight lines on sheetmetal and plate. Here, blankholders clamp the edges of the material while two opposed cutting tools perform the shearing action. During the shearing process, a moving blade descends across a fixed blade, with the gap between them determined by a required offset.
The machine oeprator can set the moving blade at an angle (typically called the shearing or raking angle) to shear the material progressively from one side to the other. As rake angle increases, the amount of force required decreases, and stroke increases.
Equipment-wise, the shearing machine (above, and Fig. 1) comprises a shear table, blankholders (F), upper and lower blades (A, E), and a backgauge (G), used to ensure that the workpiece is being cut in the proper location. Additional equipment can incude a back support, used to support the sheared part, as well as optional automatic unloading or stacking apparatus.
Achieving perfect cuts starts with using a high-quality shear equipped to minimize the effects of variable sheetmetal properties, including internal stresses and geometry. These natural effects, if not corrected and compensated for, become defects in the final product, reducing their quality.
Variables in the Shearing Process
Cutting angle (C in Fig. 1) represents the angle of the blade’s cutting edge. It influences the shearing force: Using two square-edged blades requires a higher cutting force than if the upper blade is ground at a slight angle, usually to a maximum of 87 deg. The lower blade always sits at 90 deg.Fabricators often use four-edged blades (90-deg. blades), which allows them to turn the blades, and use all four edges for shearing. Angled blades, called two-edge blades, allow use of only two cutting edges—the opposite edges have an angle greater than 90 deg. and therefore cannot be used for shearing.
Shearing angle (M, Fig. 2), less than 3 deg., has a great effect on shearing force and an important effect on twisting, which can occur when shearing thin strips.
Blade clearance, a key factor in ensuring good edge quality, represents the perpendicular distance (B in Fig. 1) between the shearing blades. The exact cutting clearance depends on workpiece thickness and material strength. Insufficient cutting clearance leads to increased tool wear and tooling costs, and cutting force will rise. Excessive cutting clearance causes the workpiece material to draw between the two blades—the cut edge will exhibit increased taper and excessive plastic deformation.
As a rule of thumb, for shearing mild steel to 10 mm thick, set blade clearance to 0.06 mm per mm of workpiece-material thickness. For work thicker than 10 mm, set blade clearance to 0.04 mm per mm of plate thickness. In Imperial units, set blade clearance to 0.06 in. per each in. of material to 1 in. thick, and to 0.04 in. per in. of plate thickness for work thicker than 1 in.
For example, to cut 16-mm-thick plate, set blade clearance to 0.64 mm (0.04 x 16). In Imperial units, shear ½-in.-thick plate with a blade clearance of 0.03 in. (0.06 in. x 0.5).
Clearing angle (D in Fig. 1), which represents the tilt of the blade ram toward the back of the shear, facilitates part separation. Most applications call for a 1.5-deg. clearing angle.
A Quartet of Common Shearing Defects
Common shearing defects include torsion, straightness error (crooking), bowing, and poor edge quality.
Twisting (Fig. 3)
Here the blade twists the plate along its axis. This typically occurs when shearing narrow strips (less than 10 times material thickness). Shearing conditions that increase this defect relate to workpiece geometry (excessively thick work, reduced width and short length), material characteristics (soft material or uneven stress distribution) and cutting parameters (high rake angle, high cutting speed).
To reduce this defect, fabricators opt to lower the rake angle and blade speed. It also proves useful to add an antitwist device—a series of hydraulic cylinders that push the plate against the top blade, providing an opposing force during shearing that is proportional to the workpiece thickness.
Crooking (Straightness—Fig. 4)
This defect, related to strip width and thickness, as well as to material strength and the previous cold-rolling direction (residual stresses), results in a workpeice curved along its plane (the surface stays flat).
To reduce crooking, fabricators should reduce the shearing angle and perform precuts along the rolling direction.
Crooking also results from using a guillotine shear, with the blade ram only supported at its ends rather than over its entire length. During shearing, the blade becomes crooked due to the cutting force and will tend to open in the center.
To eliminate the root cause of this problem, select a shear with adjustable blade pads that will oppose this deflection and keep the blade perfectly linear.
Bowing (Fig. 5)
Here, the workpiece no longer is flat—its edges raise from the plane and the material bows. This defect results from improper cutting angle and excessive workpiece-material strength.
To reduce this effect, fabricators should reduce the shearing angle and use a back support to hold the workpiece.
Poor Edge Quality
During shearing, material initially deforms plastically in a very small region (H in Fig. 6), causing a residual deformation. Afterward, the upper blade penetrates the material and forms a clean zone (I), exhibiting neat and regular cutting.
Close to the end of the shearing action, material gives in and cracks, producing a rough and irregular surface known as the fracture zone (J), which extends into the edge burr (K). The fractured zone often is not perpendicular to the plate but occurs at a variable angle (L).
To improve edge quality, focus on adjusting the blade clearance and on controlling blade wear. MF
Article submitted by Gasparini; www.gasparininorthamerica.com.
See also: Gasparini North America
Search engine optimization is actually the strategy of receiving much higher positioning in the organic search engine results page of Google, Yahoo and MSN. The internet search engine that matter one of the most are actually Google with a 62% advertising and marketing share Yahoo with twenty% and also MSN floating about along with approximately 10% in market allotment 'that indicates the online search engine you must decide on is actually Google.com cause Google.com certainly has the highest possible percentage of individuals are searching on the internet.
