Hot off the Press
End-Machining Center and CNC Saws to Tube Fabrication Industries
Tuesday, October 4, 2016
Offering equipment for tube and sheet processing, BLM Group USA (www.blmgroup.com) recently sold a BC80 CNC end-machining center and a CM602 automatic CNC sawing machine to Tube Fabrication Industries, Logansport, IN. Tube Fabrication Industries offers a core capability in the fabrication of precision aluminum and carbon-steel tubing/tubular components for automotive anti-vibration devices.
The BC80 is ideal for cut-to-length, chamfering, facing and part measurement for continuous production of bushings. The unit provides in-process part measurement and 100-percent part-length inspection with detailed SPC reporting. The CM602 is ideal for cutting short and medium-length steel, copper, brass and aluminum tubes, solid bars and profiles. It can handle tube and bar to 4 in. dia. depending on material, and cuts at speeds to 5000 rpm.
YOUR NAME *
EMAIL *
WEBSITE
