Portable Magnetic Drill with Automatic Feed and Reverse
October 1, 2016Comments
CS Unitec has introduced a new model to its MAB line of portable magnetic drills, the AutoMAB 350, which features an automatic feed mechanism with automatic reverse and shutoff. Ideal for steel fabricators, contractors and plant-maintenance professionals, the AutoMAB 350 drills holes as large as 1.5-in. dia. with annular cutters in structural steel and other materials. Max. drilling depth: 23⁄8 in. with a pilot pin, 43⁄8 in. without a pilot pin.
An integrated automatic cooling/lubrication system maximizes cutter life by reducing friction and wear. Designed for continuous use, the drill operates at 450 rpm. And, to ensure safe operation, the CS Unitec Safemag system determines whether the magnet has sufficient adhesive force on the material and alerts the user with LED indicators—green for go, red for stop. An electronic safety shutoff sensor automatically shuts down the drill motor if the magnet loses contact.
www.csunitec.com
See also: CS Unitec, Inc.
Technologies: Fabrication, Pressroom Automation
There are no comments posted.Motion Industries Names Esposito Group VP for Motion Automat...
Tuesday, January 2, 2024
MetalForming LIVE 2023: Part 3: Optimizing Press-St...
Friday, July 28, 2023 Webinar
Conveyors—Four Steps for Maximizing Performance and Minimizi...
Mike Hook Thursday, July 27, 2023
Metal Forming Strategies for Overcoming Economic Crises
Stephan Robertson Tuesday, May 19, 2020
