Hot off the Press
Kent Corp. to Rep. DieTronic Lube Systems
Friday, August 14, 2015
Kent Corp., North Royalton, OH, has announced an agreement with DieTronic Lubrication Systems of Sant’ Angelo Lodigiano, Italy, to become the exclusive North, South, and Central American representative for the company’s line of antirust machinery.
DieTronics’ product line consists of antirust machinery for the stamping and tube-and-pipe industries, where it currently has more than 200 machines in operation worldwide. Its LCP Antirust machine enables inline application of protective oil onto the surface of pipes and profiles. Oil is applied proportionally to mill speed by the encoder feedback circuit, which measures line speed and adjusts oil feed. This allows a controlled amount of protective oil to be applied consistently to the pipe or profile.
Kent Corp. provides entry equipment, strip end welders, accumulators, high-speed cold saws and tube-mill consumables to the tube-mill, rollforming and stamping industries. For more, visit www.kenttesgo.com.
YOUR NAME *
EMAIL *
WEBSITE
