MF Xtra
June 24, 2015
Wednesday, June 24, 2015
MetalForming Xtra Newsletter
June 24, 2015
Subscribe | Become a Sponsor |
Read All About It
Fiat Chrysler’s Manufacturing Excellence Coming to America
Worldclass manufacturing (WCM) is more than a catch phrase at Fiat Chrysler; it’s a way of life. Adopted first by Fiat SpA in 2005, WCM has begun to infiltrate the company’s North American facilities. WCM’s goals, per a Detroit News article: reduce waste and improve quality, efficiency and safety by focusing on 10 technical and 10 managerial pillars.
The article recounts Fiat Chrysler’s challenges (and successes) related to implementing WCM at its North American facilities.
Sponsors
Uncover Design Flaws
ETAUncover hidden design flaws before prototyping with accurate stamping simulations. Dynaform is a simulation software solution that allows engineers to accurately simulate stamping and predict formability Issues, reduce development time, validate die design, Improve efficiency and increase profitability. simulating every detail during the design stage ensures high quality formed parts and efficient manufacturing processes. Try Dynaform Today
Deburr Both Sides of Sheet Metal in One Operation
CS UnitecDeburr stainless steel, aluminum and other metal sheets up to 0.2" thick with CS Unitec’s ROLEI® BE5. Two speeds enable fine or standard deburring. Two abrasive flap wheels rotate in opposite directions to grind both sides of the metal in one pass. 28” guide rail extensions for large, thin sheets.
Success is programmable. Schuler ServoDirect Technology.
Schuler
Schuler’s reliable ServoDirect Technology is proven globally. Invest in your future with a business strategy that competes on quality with higher throughput. Gain flexibility and credibility with your customers by implementing a change in your overall process to get better bottom-line results. The payback is in your future.
Hot Off The Press
The authority on late breaking metalforming news.
Stay ahead of the curve!
> Today's News
> NIMS Partners for Job Training Along Auto Corridor
> North American Stamping Group Installs Coil Line
> Machine Safety Management Safety Software Wins Award
> Miller Electric to Host Free Welding Information Management Expo
You Ought To Know...
> Manufacturing Jobs—Separating Fact from Fiction
Hourly compensation for workers in manufacturing exceeds that in other industries by 17 percent. So, any talk of manufacturing jobs being low paying merely perpetuates the many myths about manufacturing.
Here’s a CNBC article that debunks three myths about manufacturing jobs: they’re low paying; are not very rewarding; and don’t provide opportunities for women.
New Products
The latest in metalforming and fabricating products and technology. > New Hybrid Wire for Improved EDM Machining
> CMM Laser Scanner Measures Workpiece Surfaces and Features
> Sealed Safety Eyewear Boasts Anti-Fog Lens Coating
> Electronic Resistance-Weld Head Ideal for Safety-Critical Applications
> Power Source Drives Heavy-Duty Mechanized Cutting
June MF 2015
In This Issue:
> A Quote is Only as Good as Its Calculations
Drill down into your operations to accurately ascertain the right costs, then use these costs correctly to produce real-world quotes.
> Faster, Yet Safer Press Brakes
As technology has evolved, so has the ability for press brakes to fulfill a complex task: improve operator safety and productivity at the same time.
What's Trending?
July
> In-Die Sensing
> Press Controls
> Resistance Welding
August
> Hydraullc Presses
> Die Design Software
> Laser Cutting
September
> Automation
> Quick Die Change
> Plasma Cutting
Become Involved
Subscribe to the Magazine
Become a Sponsor
Post Jobs
2015 Media Kit
MetalForming Jobs
Plant Manager (NJ) / Eaton
Associate Certified Welding Inspector (FL) / Universal Engineering Sciences
Plant Manager (TN) / Johnson Controls, Inc.
Welder / Fabricator (CA) / C&K Johnson Industries
Tooling Engineer (WI) / Luvata Appleton LLC
Powered by MetalForming & PMA
See also: ETA Dynaform, CS Unitec, Inc., Schuler Incorporated
YOUR NAME *
EMAIL *
WEBSITE
