MF Xtra
May 13, 2015
Wednesday, May 13, 2015
MetalForming Xtra Newsletter
May 13, 2015
Subscribe | Become a Sponsor |
Read All About It
The Dollar’s Power Surge and the Trans-Pacific Partnership
Blame the sharp increase in the value of the U.S. dollar for the stalled manufacturing-job market. So says a recent Washington Post article which notes that the U.S. trade deficit in manufactured goods has increased by more than $100 billion over the last 12 months.
The authors go on to explain why the ongoing negotiation of the Trans-Pacific Partnership, meant to create avenues to boost U.S. exports, contains one serious flaw: the lack of currency provisions. “Currency interventions by Japan, Malaysia and Singapore have cost us 250,000-320,000 jobs annually over the past few years,” the article claims.
The article offers insights into the relationships between the currency imbalance, the trade deficit and employment.
Sponsors
Uncover Design Flaws
ETA Dynaform Uncover hidden design flaws before prototyping with accurate stamping simulations. DYNAFORM is a simulation software solution that allows engineers to accurately simulate stamping and predict formability issues, reduce development time, validate die design, improve efficiency and increase profitability. Simulating every detail during the design stage ensures high-quality formed parts and efficient manufacturing processes.
Try DYNAFORM Today
Professional Surface Finisher
CS UnitecCS Unitec’s PTX Eco Smart produces matte, satin and other fine surfaces up to a mirror finish on steel, stainless steel and nonferrous metals. It also removes welds, deep scratches, oxidation, rust and paint. Patented abrasive-mounting system allows grinding/polishing wheels to be changed in seconds, without tools or hardware.
Hot Off The Press
The authority on late breaking metalforming news.
Stay ahead of the curve!
> Today's News
> NIMS Commits to Bolstering Competency-Based Internships
> Software Cuts Die-Machining Time for South African Tool Builder
> Metalforming Industry Movers & Shakers
> United Performance Metals Unveils Redesigned Website
You Ought To Know...
> Make Way for Sensors—Lots and Lots of Sensors
“Over the next 10 years, factories and manufacturing facilities will worry less about buying new equipment and more about outfitting their spaces with an array of high-tech sensors and routers.”
So goes this blog post summarizing a new report from McKinsey & Company titled Industry 4.0: How to Navigate a Changing Industrial Landscape. The consulting firm estimates that as we usher in the “techie industrial revolution” over the next decade, manufacturers will only have to replace 40 to 50 percent of their equipment.
Also noted: Among the skills sets expected to be in high demand are those that require handling of data and analytics. Offered as an example application of how sensors will impact manufacturing is use of “smart” sheetmetal-handling robots equipped to detect and reject defective material.
Sponsors
Versatility Industrial Tool Storage Cabinets and Change-Over Carts
Versatility Engineered for lean- manufacturing principles and designed for more efficient and productive fabrication, Versatility Tool storage cabinets and carts protect and organize your press-brake and turret-press tooling, and save valuable time.
  • European Press Brake Tooling
  • Amada Fixed Height Tooling
  • Traditional American Tooling
  • Wila NS, Wilson WT and Trumpf Tooling
  • Wila American, Wilson American Tooling and Trumpf American Tooling
Machining Without Coolant
ExairReplace messy mist systems and improve dry machining with clean, cold air! EXAIR’s Cold Gun Aircoolant System improves tolerances, tool life and production rates by cooling with 20°F air. The Cold Gun is ideal for tool sharpening, drill and cutter grinding, milling, band sawing, more.
May 2015 MF
In This Issue:
> Understanding the New, Stronger Automotive Steels
No manufactured product better illustrates the contribution of material science to society than the current generation of automobiles, featuring improved performance in nearly every measurable category--handling, fuel economy, safety, etc.--due in large part to a slew of new steels. Equally impressive has been the technology developed to form these new alloys.
> Optimize Aluminum-Welding Performance
Here's an introduction to modified pulsed-spray transfer welding, and some valuable advice on how to weld aluminum profitably.
What's Trending?
June
> Lubrication
> Mechanical Presses
> Waterjet/Laser Cutting
July
> In-Die Sensing
> Press Controls
> Resistance Welding
August
> Hydraulic Presses
> Die Design Software
> Laser Cutting
Become Involved
Subscribe to the Magazine
Become a Sponsor
Post Jobs
2015 Media Kit
MetalForming Jobs
Progressive Tool & Die Maker (CT) / Bridgeport Fittings
CNC Machinist (1st Shift) (NY) / GE Transportation
Tooling / Design Engineer (FL) / Kaman Integrated Structures and Metallics
Welder Trainee - Exelon Industrial Services (MD) / ComEd, an Exelon
Tool & Die Maker (IN) / United Technologies Corporation (UTC)
Powered by MetalForming & PMA
See also: CS Unitec, Inc., ETA Dynaform, Exair Corp, Versatility Tool Works & Mfg.
YOUR NAME *
EMAIL *
WEBSITE
