Bradford White Standardizes on Coe Coil-Line Controls
August 1, 2013Comments
Coe Press Equipment, Sterling Heights, MI, has installed two new coil lines at the Bradford White water-heater manufacturing plant in Middleville, MI, following the retrofit of two 1999-vintage ServoMaster Series 3 roll feeds with ServoMaster retrofit packages. The retrofit packages include replacement of the operator interface, controls console, servo motor, cable sets and pneumatic valve. The upgrade provides streamlined entry of machine setup information, and enhancements to the operator prompts, machine diagnostics and serial communications to the press controls. Additional capabilities include production-data reporting and downloading of setup data or job-number selection.
