Hot off the Press
Ace Metal Crafts Moves to New Digs
Friday, August 26, 2011
An 82,000-sq.-ft. plant in Bensenville, IL, is the new home of Ace Metal Crafts, specialists in stainless-steel fabrication. The firm provides laser cutting, forming, welding, sanitary finishes and value engineering. It has stocked the new, larger plant with plenty of new equipment, including a third laser-cutting machine and a nitrogen-generating system to support its laser-processing operations, as well as additional welding equipment that boosts capacity by 30 percent. More at www.acemetal.com.
