Stainless-Steel Service Center Adds Fourth Waterjet-Cutting Machine
March 1, 2012Comments
Penn Stainless Products, Inc., Quakertown, PA, has added a Flow Corp. Mach 3 waterjet-cutting system to its stable, capable of cutting sheet and plate to 78 by 288 in. The company’s fourth waterjet-cutting machine boasts a 94,000-psi pump that boosts cutting speed by as much as 45 percent compared to using conventional 60,000-psi pumps.
Flow equips the Mach 3 with its Dynamic Waterjet motion system that, say company officials, eliminates the inside corner washout and taper produced by conventional systems, by tilting the cutting head to the side and forward during cornering. Penn Stainless processes stainless-steel sheet, plate, bar, structural shapes and pipe and tubular products.
Flow Intl. Corp.: 253/850-3500; www.flowwaterjet.com
See also: Flow International Corp.
Technologies: Cutting
There are no comments posted.New Line of Wear-Resistant Waterjet Nozzles
Friday, February 24, 2023
AAG Brand Refresh Features New Logos and an Updated AXYZ Web...
Thursday, December 15, 2022
