Tube-Bending Lube
September 1, 2010Comments
ITW Rocol North America, Glenview, IL, introduces Accu-Lube JL-12, an opaque gel formulated specifically for tube-bending applications. Fabricators can either pump or hand-apply the lube directly to the tube or to the bending mandrel. No cleaning is required before welding, and in applications requiring painting or plating, the gel is easily removed. Compared to using conventional lubricants that flow down tubes, Accu-Lube JL-12 will reduce consumption, improve housekeeping, and prolong tool or mandrel life, according to company representatives. The gel is available in 5- and 55-gal. containers.
ITW Rocol North America: 847/657-5343; www.rocolnorthamerica.com
See also: ITW Fluids North America
Technologies: Lubrication
There are no comments posted. Lubrication
Brad Kuvin Friday, January 19, 2024
Lubricant Use/Misuse: Reducing Cost per Stroke
Wednesday, January 17, 2024
PMA Adds Courses on Lubrication Technology its METALFORM EDU...
Friday, October 20, 2023
New Hires at Tower Metalworking Fluids
Friday, September 29, 2023
Tower Metalworking Fluids Turns 90 in October 2023
