Hot off the Press
Bachman Acquires Machining Center
to Bolster Production-Machining Capabilities
Friday, February 20, 2009
The CNC machining facility of Bachman Machine Co., St. Louis, MO, will soon welcome the addition of a new CNC double-column vertical machining center. Bachman will use the machine to provide added capacity to its tool and die operation, as well as support and grow its production-machining operations. The machining center, a DCV series 4025 model from Taiwanese builder YCM, features a 161 by 94-in. table and a maximum allowable load of 44,000 lb. Bachman Machine is a manufacturer of metal stampings, progressive dies, plastic injection-molded parts and production CNC machined parts; www.bachmanmachine.com.
