Buffalo Stamper Welcomes 1000-Ton Mechanical Press
July 1, 2008Comments
P&G Steel Products, Buffalo, NY, has added a 1000-ton mechanical transfer stamping press to its pressroom. The press has a bed size of 120 by 48 in. and will operate in line with a heavy-duty Sesco feed line with sheet-thickness capacity of ½ in. Also on the to the facility is a 46-in. double-spindle vertical grinder.
